I have a problem to read gh script component. I used this code block.
# convert breps and points
# create list of input trees
right_tree = gh.DataTree("RH_IN:Right Surface")
right_tree.Append([0], [right[0].Geometry])
left_tree = gh.DataTree("RH_IN:Left Surface")
left_tree.Append([0], [left[0].Geometry])
points_tree = gh.DataTree("RH_IN:Pt")
points_tree.Append([0], [density_points[0].Geometry, density_points[1].Geometry, density_points[2].Geometry])
trees = [right_tree, left_tree, points_tree]
output = gh.EvaluateDefinition('2021_03_11_Brace_Generation_Script_4.gh', trees)
print(output)
2021_03_11_Brace_Generation_Script_4.gh (4.7 KB)
I’ve got this error.
{‘statusCode’: 500, ‘message’: ‘Something went horribly, horribly wrong while servicing your request.’, ‘details’: “Nancy.RequestExecutionException: Oh noes! —> Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: {. Path ‘values[0].InnerTree.0[0].data’, line 1, position 645984.\r\n at Newtonsoft.Json.JsonTextReader.ReadStringValue(ReadType readType)\r\n at Newtonsoft.Json.JsonTextReader.ReadAsString()\r\n at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateDictionary(IDictionary dictionary, JsonReader reader, JsonDictionaryContract contract, JsonProperty containerProperty, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)\r\n at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)\r\n at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)\r\n at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)\r\n at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)\r\n at compute.geometry.ResthopperEndpointsModule.Grasshopper(NancyContext ctx) in C:\src\compute.geometry\ResthopperEndpoints.cs:line 66\r\n at Nancy.Routing.Route.<>c__DisplayClass4.b__3(Object parameters, CancellationToken context)\r\n — End of inner exception stack trace —\r\n at Nancy.NancyEngine.InvokeOnErrorHook(NancyContext context, ErrorPipeline pipeline, Exception ex)”}
