I am compiling .dll library with some geometry helper functions.
I am not running the project in debugging mode. Just would like to add or change some bits of code in my .dll while working without restarting rhino.
The problem is that when I want to compile the code I need to close rhino else I get error in visual studio:
Could not copy "obj\Debug\RhinoJoint.dll" to "..\..\..\..\..\AppData\Roaming\Grasshopper\6\Libraries\RhinoJoint\RhinoJoint.dll". Exceeded retry count of 10. Failed. The file is locked by: "Rhino 6 (2364)" RhinoJoint
The .dll is loaded in grasshopper C# script editor, ideally I would like to update the .dll while working, but restarting rhino is what I would like to avoid.
Is there any workaround?
and it saves a lot of time.
