Compare Data Branches values Two by Two without itself
Hi everyone
I looked for a similar question in the forum but I did not find or I could not find
is there any way (or a component) to make comparisons or tests for the duplicate presence between the values ​​of the branches of a data tree but two by two and to have the results separated
1- without the branch being checked with itself.
2- without repetition: if for example {1} has been compared to {2} it is not worth comparing {2} to {1}
I know there is the Cross reference component but I don’t think it is suitable for what I want. I don’t know how to do it.
thanks in advance
CompareBranchTwoByTwo.gh (17.3 KB)
Hi
this for the first branch. How to iterate ? any idea.
Thanks
CompareBranchTwoByTwo-02.gh (5.6 KB)
It seems you need Cross Reference with “Diagonal”.
CompareBranchTwoByTwo-02_re.gh (16.6 KB)
thank you very much @HS_Kim it’s perfect, I’m still looking at what you did but at first glance why there are 55 branches as result instead of 28 because …
I think it should be 28
but maybe i’m wrong
You can also try Cross Rreference with “Lower(or upper) Triangle(Strict)”.
okay i will do that thank you
Thank you @HS_Kim
:pray: :pray: :pray:
Hi everyone
Please, I still find it difficult to manipulate Data trees. How to replace in the original data tree all duplicate items with “null”
Thank you
CompareBranchTwoByTwo-03.gh (6.7 KB)
