I use RhinoScript into c# and I have the color code problem
rs.ObjectColor(surface, [150,0,0]);
For some reason the color code is rong, what is the rigth code for this command?
the color code should be a list with the 3 RGB channels, But how can I pass this list using
the RhinoScript on C#
Thanks
clement
December 13, 2018, 3:36am
2
Hi @MatrixRatrix , have you tried like below ?
color = System.Drawing.Color.FromArgb(150, 0, 0)
rs.ObjectColor(surface, color)
_
c.
Hello @clement ,
I try you comand and dont work, seams that “rs.ObjectColor(surface, color)” only acept Int number.
DanBayn
December 13, 2018, 11:15am
4
I think the issue is that you made your RGB values a list when they should be a tuple. This works for me:
rs.ObjectColor(surface, (150,0,0))
Hope this helps,
Dan
DanBayn:
Hope this helps,
Dan
@DanBayn , thank you,
this code " rs.ObjectColor(surface, (150,0,0))" work for me to, but is on Python editor, I not using
the Python editor.
I using C# with rhinoscript plugin:
var rhinoscript_object = RhinoApp.GetPlugInObject(“RhinoScript”);
var rs = (IRhinoScript)rhinoscript_object;
var surface= rs.GetObject(“Select part”, 8);
So, on C# this list dont work.
How about rs.ObjectColor(surface, Array(150,0,0))
@Helvetosaur , dont work ,
Only work if the command is “rs.ObjectColor(a, 16744272);”,
I can not identify the integer type matches the color “16744272”, is a decimal but,
here is the table for decimal color?
DanBayn
December 13, 2018, 6:32pm
9
Sorry, I missed that in your original post.
I also seem to remember using RGB(150,0,0) from Rhinoscript days…
