I need to have a closed polysurface with surface direction outwards on my boat hulls to be able to use model information in subsequent plugins/software.
I can manage to get the individual surfaces to have correct direction, but when I join the last surface, I often end up with a closed surface with direction pointing inwards - i.e. direction of all surfaces have been flipped
Most of the time, I can bypass this problem by trimming the “non-essential” part of my hull (a distance above waterline) and close the polysurface by means of cap command or an imaginary deck surface.
However, for some models, I cannot manage to create a closed polysurface with direction pointing outwards, no matter what (limited) surface tools I try.
Does anyone have an idea what causes this, and how to avoid it / workaround??
-Lefty Looser-
PS! Due to client agreement I cannot upload model files
What happens if you explode the model, select all the surfaces, run _RebuildEdges and then try to re-join?
(before you re-join you might want to use SelSmall and see if you have any micro-surfaces in there)
Tried this in both v5 and v6 (use mainly v5 since the plugins are not updated for v6).
Ran the commands with default values/tolerances.
Result: v5 created two naked micro-edges (which I have to fix to be able to create a closed polysurf, so I just jumped to v6-testing, since that has the new and brilliant _RemoveAllNakedMicroEdges command)
v6 managed to rebuild edges and join surfaces to a closed polysurf without any naked edges - alas the new polysurf was also inside out
Pascal, You nailed it!
It is the nature of many of my models, that some surfaces have different extent in e.g. X-direction, which makes me end up patching the open parts - usually by means of _EdgeSrf. Even so, this occasionally results in a naked edge (which I don’t understand, since EdgeSrf should result in position accuracy?)
Anyway, my quick fix for generating the required closed polysurface, have been to simply add a EdgeSrf between these two naked edges, which seems to be sitting on top of eachother.
Strange still is the fact that some of my models having this “super skinny” surface can be closed without flipping inside out - but at least now I know the root cause when they do flip.
