I found icon Chebyshev Strip, but didn’t catch any info in Evolute primer or forum about this tool. What is that? How to use it?
Thanks in advance,
Bojan
Thanks in advance,
Bojan
For a basic documentation about etCheybshevStrip please press F1 after starting the command, or navigate directly to the help file via Help->Plugins->EvoluteTools for Rhino. Please find it copied below. Post questions if you have any.
etChebyshevStrip
Creates Chebyshev mesh strips on the reference surface starting from input curves.
Available in EvoluteTools PRO
Pure quad meshes with constant edge lengths are called Chebyshev meshes. As an example such meshes are useful to study the behavior of textiles or wire grids with quad connectivity when being deformed to cover a surface. This command creates Chebyshev mesh and surface strips starting from mid curves which lie on or very close to the reference surface. The Chebyshev strips are created by successively extending them in both directions until one of the stopping criteria is reached.
Please note that Chebyshev meshes exist only for surfaces with non-positive Gaussian curvature.
This command requires a reference surface to be set, use the etSetReference command for that purpose.
Parameters:
Example:
Two Chebyshev strips approximating a reference surface, created starting from geodesic curves on the reference surface (shown in red).
