Changing layer event?
Hello
What is the event used when an object changes its layer?
Hi @anon39580149,
you might try ModifyObjectAttributes event and compare the object’s layer index, eg:
import Rhino
import scriptcontext
def MyLayerChangeEvent(sender, e):
    if e.OldAttributes.LayerIndex != e.NewAttributes.LayerIndex:
        layer = scriptcontext.doc.Layers[e.NewAttributes.LayerIndex]
        print "{} changed layer to: {}".format(e.RhinoObject, layer.FullPath)
def MyToggleEvent():
    my_event_name = "MyLayerChangeEvent"
    if scriptcontext.sticky.has_key(my_event_name):
        print "removing event"
        func = scriptcontext.sticky[my_event_name]
        scriptcontext.doc.ModifyObjectAttributes -= func
        scriptcontext.sticky.Remove(my_event_name)
    else:
        print "adding event"
        func = eval(my_event_name)
        scriptcontext.sticky[my_event_name] = func
        scriptcontext.doc.ModifyObjectAttributes += func
MyToggleEvent()
_
c.
Thank you @clement
