Hey guys, i tried to change a dot secondary text and dosen’t work , what i m missing?
textDot = rs.GetObject(“Select textDot”, rs.filter.textdot)
textDot = rs.coercegeometry(textDot)
print textDot.SecondaryText
textDot.SecondaryText = “Test”
when you coerce the geometry a copy is made
you just need to reference the actual thing in the rhino document
import scriptcontext as sc
r = rs.GetObject(' pick text dot', rs.filter.textdot)
td = sc.doc.Objects.FindId(r).Geometry #this is what you want
print(td.SecondaryText)
td.SecondaryText = 'bigger'
Thank you @will_wang for explanantion.
Also you re code make a copy of object ,but with replace function will make it correctly
sc.doc.Objects.Replace(r,td)
sorry forgot to include this
there must be a CommitChanges
method in the end
fwk
(Fwk)
June 13, 2021, 4:26am
5
Hi, I cannot get the text dot secondary text to refresh in the rhino document. I tried the CommittChanges, but I got textdot has no attribute CommittChanges. What did i miss?
dale
(Dale Fugier)
June 14, 2021, 2:53pm
6
Try this:
mport Rhino
def coercetextdot(id, raise_if_missing=False):
geom = rs.coercegeometry(id, False)
if isinstance(geom, Rhino.Geometry.TextDot): return geom
if raise_if_missing: raise ValueError("unable to convert %s into TextDot geometry"%id)
def test_text_dot():
dot_id = rs.GetObject('Select text dot', rs.filter.textdot)
if not dot_id: return
dot = coercetextdot(dot_id)
if dot.SecondaryText: print(dot.SecondaryText)
dot.SecondaryText = dot.SecondaryText + ' Test'
sc.doc.Objects.Replace(dot_id, dot)
sc.doc.Views.Redraw()
if __name__ == "__main__":
test_text_dot()
– Dale
dale:
def coercetextdot(id, raise_if_bad_input=False):
Hi Dale,
You renamed your raise_if
variable in one location but not the other…
Graham
fwk
(Fwk)
June 15, 2021, 6:08am
8
Works fine. TQ.
got "unsupported operand type(s) for +: ‘NoneType’ and ‘str’,
if secondary text is empty.
is the CommitChanges
workflow not valid anymore?
would you recommend the Objects.Replace
paradigm over CommitChanges
Henry_Wede
(Henry Wede)
September 10, 2024, 2:48am
10
What is the solution for adding secondary text to a dot that does not already have it?
The code that I am trying to use looks like this
geom = rs.coercegeometry(pointGUID, False)
print(geom)
print(type(geom))
geom.SecondaryText(f'{self.pointList[n].deviation:.4f} mm')
sc.doc.Objects.Replace(pointGUID, geom)
The print statements say:
<class 'Rhino.Geometry.TextDot'>
so the geom object is not None
Error is:
TypeError: 'NoneType' object is not callable
(the line number is not shown but the error is from the geom.SecondaryText(…
Which sounds like Rhino thinks it is None?
Have you tried geom.SecondaryText = f'{self.pointList[n].deviation:.4f} mm'
Henry_Wede
(Henry Wede)
September 10, 2024, 1:44pm
12
Thank you!
My fault for not reading more carefully - I was getting hung up on the NoneType part of the error message.
