I just upgraded from Rhino 5 to Rhino 6 and the toolbar text size is different (see image attached).
I’m wondering if there is a way to make the text appear smaller to match what I’m used to in Rhino 5.
Thanks!
Thanks!
Hello - no, there is no way to change that that I know of.
Pascal is right. There is no separate setting for that inside Rhino.
The size is based on your Windows screen resolution and text scaling sizes In Windows’ Display Settings.
Thanks, good to know.
I don’t want to make other programs smaller.
I’ll get used to it!
I believe I figured this out, or I at least enlarged mine from the default. File/ Properties/ >Toolbars When you click on the down arrow rather than the text, a sub box shows up as “size and styles” / Button Size/ Large
