Hi @will @stevebaer @AndyPayne
What would be the best way to change an ApiKey for compute after it has been set running the bootstrap, following the deployment instructions here ?
Hi @dadandroid. The bootstrap script writes the API Key to an environment variable on the VM (or server). To change it, you simply need to edit the RHINO_COMPUTE_KEY value in your environment variables. Hope this helps.
Thanks @AndyPayne that helped! After deploying the server in AWS and succesfully running the bootstrap following the instructions in the devdocs I try to test by hitting the /activechildren endpoint with my public IP address similar to http://52.168.38.105:80/activechildren but I get a response of 0. Do you know why this might be happening?
I do get compute.rhino3d when I type just the public address (without the endpoint)
Have you tried restarting your VM? That might help. If you are sending the /activechildren endpoint as a GET action, you donât need the API key. The API key is only checked when submitting a POST request⊠so I donât think it has to do with that. However, restarting the server might help. Also, are you able to PING the IP address of the AWS server?
I do get a ping back from the AWS IP address, and the browser displays compute.rhino3d when I type just the public address (without the endpoint)
Do you get anything when you use the /healthcheck endpoint? It should respond âHealthyâ if all is well. Also, have you tried sending a very simple Hops definition to this server? Make sure you enter the AWS server URL and the API key in the Grasshopper Preferences section. You may need to restart Rhino after you do this before you send the Hops definition over to that address.
/healthcheck returns healthy but /version or /sdk donât work
I did try with hops and I get:
Are you sure the definition that youâre trying to send over to the remote machine isnât using a third party plugin that might be installed locally on your own machine, but hasnât been installed on the remote machine? The reason I ask is that hops is clearly getting something back from the server because it populated the inputs and outputs (ie. Radius, Count, etc.). If it couldnât communicate with the server at all, then that step would have failed. In addition, we know itâs likely not the API Key because to get the inputs and output response, hops sends a POST request and gets a response back which tells it how to build out the inputs and outputs. Before compute processes the POST, it check the authentication against the API key, so we likely know that part is working. My hunch is that there is a component that isnât loaded on the remote machine that youâre trying to use and itâs failing at that step.
Can you do me a favor and simply try to load this file into Hops and send it over. It is a really basic grasshopper definition that I know contains know 3rd party components.
HelloWorld.gh (3.4 KB)
@AndyPayne I get this from running your definition:
Iâm quite sure there were only native gh components in my previous definition. My guess is that in the previous screenshot that I sent it was the cachĂ© from running the definition locally providing inputs/outputs for hops
running SampleGHDelaunayMesh from the developer samples with my credentials gives me the following error:
Ok. Thanks for posting all of this. It appears to be the same issue as this user is having: Trouble following Compute Deployment tutorial. I am looking into this and will report back shortly.
@dadandroid The errors you are reporting seem very similar to the ones reported in the other thread. In that thread, the user posted a copy of their log file which contained the error below.
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
Usually, these errors occur when Rhino fails to retrieve a valid license⊠which makes me wonder if there was a typo when you copied the Auth Token over in the bootstrap script⊠or if somehow it didnât get saved into the environment variables correctly.
Hereâs what I would recommend. First, goto this guide and follow the instructions on retrieving your Auth Token from the Rhino portal. Once you see your Auth Token displayed on the screen, click the âCopyâ button to copy the entire string of text.
Next, go into your VM and click on the search bar and start typing âEnvironâ. You should see a link that says âEdit the system environment variablesâ. Click that and in the System Properties dialog click on the button at the bottom which says Environment Variables. In the System Variables list scroll down till you see the variable RHINO_TOKEN. Click on that row and select Edit. In the Variable Value input, replace the existing string with that you just copied from the Rhino portal.
Restart your AWS instance and then try to hit the /activechildren endpoint. Hopefully at this point, you will see an integer value greater than zero.
@AndyPayne manually setting the RHINO_TOKEN didnât work but I managed to get some /activechildren finally after running the bootstrap again with a new token. Now Rhino opens in the VM and I can run your sample definition in hops
I am now able to run SampleTkinter from the python Developer Samples with my credentials, however Iâm still not able to call compute from the browser using any of the other js dev samples. I keep getting the same error I posted above in the console related to CORS policy:
Do you have any idea what might be causing this? If it helps, here are the ports that are open in my instance:
Iâd be happy to provide any additional info to make this work
more info:
Running your simple HelloWorld.gh definition in a local compute server through the browser works:
Evaluating the same definition in the AWS compute server produces the same error in the console in the browser:
Access to fetch at âhttp://X.XX.X.X/grasshopperâ from origin âhttp://127.0.0.1:5500â has been blocked by CORS policy: Response to preflight request doesnât pass access control check: No âAccess-Control-Allow-Originâ header is present on the requested resource. If an opaque response serves your needs, set the requestâs mode to âno-corsâ to fetch the resource with CORS disabled.
Using my compute address to run the definition in Hops works. Even evaluating the definition in python (Using export python sample... in hops) in my server does return a response with no errors:
My server seems to work everywhere but in the browser⊠Any thoughts @AndyPayne @will @stevebaer ?
So, I think the issue here is that you need to include your API key as part of the request header. Remember, when you ran the bootstrap script, it stored the API key in an environment variable. So, now when you make a request to your remote rhino compute instance, it will check to see if there is a value stored in that environment variable and if there is then it will check to see if they match before proceeding. When you run Hops (assuming youâve installed the latest build and have input an API Key in the Hops Preferences section) this API Key gets sent as part of the request (in the header) so that the request is authenticated and the app knows that its âyouâ who sent the request. But, if youâre sending a request via some other means (a web request for example)⊠then youâll need to also include the API Key as part of that request. The request uses a json object in the header to store the API Key. The key should be RhinoComputeKey and the value should be whatever your API Key is. So, something like this:
"RhinoComputeKey" : "b8f91f04-3782-4f1c-87ac-8682f865bf1b"
Hopefully this helps. Let us know if this resolves the issue.
@AndyPayne I thought the Api key is being sent in the request if itâs included in the .js script by setting RhinoCompute.apiKey:
I can see that the request includes RhinoComputeKey in the header with a key that matches RHINO_COMPUTE_KEY env variable in the VM:
@AndyPayne so the Api key seems to be going with the request⊠any other thoughts on why I keep getting this error in the console?
Hi @dadandroid Sorry for the delay. Yes, I think youâre right. I think youâve got the API Key in place for the request header. Iâm going to need to see if somehow IIS is messing with the CORS policy and if thatâs why you might be getting this error. Iâll report back my findings.
Hi @dadandroid
In your index.html page, you likely have a script tag. Something that looks like this?
<script type="module" src="./script.js"></script>
What happens if you add the crossorigin tag to that? So something like this?
<script type="module" src="./script.js" crossorigin="anonymous"></script>
Does that fix the issue youâre seeing?
Hi @AndyPayne. Iâm afraid it doesnât. The CORS error persists after adding the crossorigin tag
Are you able to replicate this issue?
