Hi Python Gurus,
I’m writing a python script for capturing an image of a detail view on the layout page. So far this proves to be a challenge to identify the viewport and its correct location on the layout page to do the print-screen. I have gotten the method to work for specifying that I click the top left and bottom right corner of the detail view to determine the location and size of the capturing. However, this method can be quite tedious, and I want to simplify it even more where I can just select a detail view and capture it with its correct viewport size (ratio).
Also, the resolution of the image is limited by the DPI of the screen for doing a print-screen like capture. Would it be possible for Rhino to do a viewport print-screen with a specify resolution ignoring the DPI of the screen?
I’m writing a Python script to capture an image of a detail view on a layout page in Rhino. I currently have a method that works by manually clicking the top-left and bottom-right corners of the detail view to determine the capture area. However this process is quite tedious, so I want to simplify it by clicking to select a detail view and capturing it at its correct viewport size (aspect ratio).
Also, the resolution of the captured image is currently limited by the screen’s DPI (72) since it’s doing a print-screen capture. Is there a way in Rhino to capture a viewport image at a specified resolution (ignoring the screen DPI)?
Please see my sample script. Any advice? Thanks in Advance.
import Rhino
import scriptcontext as sc
import System.Drawing as sd
def capture_selected_detail():
# Select a detail view object
detail_id = rs.GetObject("Select a detail viewport", rs.filter.detail)
if not detail_id:
print("No detail selected.")
return
selected_obj = sc.doc.Objects.Find(detail_id)
if not isinstance(selected_obj, Rhino.DocObjects.DetailViewObject):
print("Not a valid detail view.")
return
# Find the layout view that owns this detail
layout_view = None
matched_detail = None
for view in sc.doc.Views:
if isinstance(view, Rhino.Display.RhinoPageView):
for detail in view.GetDetailViews():
if detail.Id == selected_obj.Id:
layout_view = view
matched_detail = detail
break
if layout_view:
break
if not layout_view or not matched_detail:
print("Could not find parent layout for detail.")
return
# Use the detail geometry's bounding box
bbox = matched_detail.Geometry.GetBoundingBox(True)
if not bbox.IsValid:
print("Invalid bounding box.")
return
# Transform bounding box to page coordinates
xform = matched_detail.WorldToPageTransform
pt1 = xform * bbox.Min
pt2 = xform * bbox.Max
# Debug: Print transformed points
print("Transformed points: pt1 = " + str(pt1) + ", pt2 = " + str(pt2))
# Create crop rectangle
x = int(min(pt1.X, pt2.X))
y = int(min(pt1.Y, pt2.Y))
width = int(abs(pt2.X - pt1.X))
height = int(abs(pt2.Y - pt1.Y))
crop_rect = sd.Rectangle(x, y, width, height)
# Debug: Print crop rectangle
print("Crop rectangle: " + str(crop_rect))
# A3 size at 300 DPI
dpi = 300
media_width = int(420.0 * dpi / 25.4)
media_height = int(297.0 * dpi / 25.4)
# Simplified capture settings for the layout
settings = Rhino.Display.ViewCaptureSettings(layout_view, dpi)
settings.SetLayout(sd.Size(media_width, media_height), crop_rect)
# Save the image
filename = rs.SaveFileName("Save captured detail", "PNG Files (*.png)|*.png||")
if not filename:
print("No file selected.")
return
print("Attempting to capture the image...")
try:
# Perform the capture
bitmap = Rhino.Display.ViewCapture.CaptureToBitmap(settings)
if bitmap:
print("Capture successful!")
# Save the captured bitmap
bitmap.Save(filename, sd.Imaging.ImageFormat.Png)
print("Saved image to: " + filename)
else:
print("Failed to capture image - bitmap is None.")
except Exception as e:
print("Error during image capture: " + str(e))
# Run the script
