Hi all,
I am just wondering if anybody knows how I could cap an extruded surface and a lofted surface generated in grasshopper, like so:
The cap component was the obvious first choice, however as most of you may have guessed that didn’t work and I just ended up with two capped objects, like so:
The desired effect I’m after is to have my object look like this, but done entirely in grasshopper.
I suspect it has something to do with identifying the edges, however I have had no luck so far. Any help would be much appreciated!
Thanks, Callum.
