Cant join all the surfaces
hi! does anyone know how to join all this surfaces or maybe these surfaces arent join able? i wanna make the model connect to brep on grasshopper or at least can mesh them but it needs to join all the surfaces first. thanks in advance!
here’s the file since i cant send it here bc the file is too big
this file contains a lot of breps and many of them are closed - so they can not be joined to others
oof… this file is a bit of a mess.
you will want to run showedges set to show naked edges.
you will need to remove surfaces that overlap, trim stuff, join up stuff that is not joined etc..
see this video this is the process you’ll need to work thru to join this up.
