Can you help me please grasshopper-rhino 8
PARAMETRIC MODELING – Grasshopper
Design a building using parametric modeling principles in Grasshopper.
The project must be fully parameter-driven, allowing the geometry to be modified by adjusting parameters within Grasshopper.
There is no requirement to bake the building geometry into Rhino; the parametric definition itself is sufficient.
You may recreate or adapt an existing example from an online tutorial and use it as a reference. You are also free to combine multiple structures, for example creating a form inspired by a bridge, overpass, or interconnected buildings.
Would it be possible for you to create the parametric object and share a download link with me? I would be very grateful for your help.
If you search on this forum, you will surely find enough nice a well made designs to download. Using them as they are would be plagiarism. So recreate it untill it is a designed by @Kosovo_Beast
Good luck, regards, Eef
Please review the ‘Help us help you’ page..
