Can we have a ToNURBs with options Grasshopper component please?
Hi Guys,
My junior designer ran into an issue today.
He has a SubD object which he is pulling into GH to script up a number of Boolean operations.
In the course of GH doing the booleans it converts the SubD into a Brep, however the default on this conversion unpacks all the faces into separate surfaces.
If you convert the SubD using the ToNURBs you have the option to pack faces.
It is less than ideal in the work flow to have to manually do the conversion to get the packed version.
Attached is an example of what we are seeing.
I checked the API and it appears the options are not exposed yet, so we couldn’t ‘roll our own’ in C# either.
Can you please add a ToNURBs with options into Grasshopper for us? PLEASE?
201211_ToNURBS with options in Grasshopper please.gh (6.8 KB) 201211_ToNURBS with options in Grasshopper please.3dm (675.0 KB)
Opps - I may have been mistaken about the options being available in the API
SORTED - wrote the solution in GH Python - attached.201211_ToNURBS with options in Grasshopper sorted.gh (6.2 KB) 201211_ToNURBS with options in Grasshopper sorted.3dm (914.9 KB)
Hi -
I added the feature request as RH-61955.
Thanks @wim
Thanks @kiteboardshaper this Python script was super helpful.
Thank you! Never thought to look for this before, very helpful even years later with R8
thanks a lot, super useful!
came from this thread:
Thanks guys,
I’ve added this as a utility component to DKUI - mostly for my own use - but others might find it handy:
Cheers
DK
250929_SubD to Nurbs with faces packed in DKUI.gh (8.5 KB)
