Our users are CNC machine operators, they are often new to CAD and Rhino looks SCARY.
You and I know that it is not.
However to lessen the visual complexity we often strip out a lot of the Rhino toolbars initially.
We save this as a Rhino Window Layout *.rhw file.
I have distributed this file with our plugin within the .yak file.
However what I’d like to do is to make this .rhw Window layout appear in the Window Layout List - and ideally prompt users if they want to change when the plugin is first installed.
Where are the .rhw files stored on disk? can I add to them? Are there any methods in RhinoCommon to install or activate a window layout?
The WindowLayout command can be run headlessly -WindowLayout which allows for importing a layout and restoring a layout, a user will however have to say Yes/No when changing to the layout.
Object name: 'Rhino.UI.Internal.TabPanels.Controls.TabPanelModalDialog'.
at Eto.Widget.get_Handler() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Widget.cs:line 88
at Eto.Forms.Control.get_Handler() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Controls\Control.cs:line 22
at Eto.Forms.Dialog.get_Handler() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Dialog.cs:line 126
at Eto.Forms.Dialog.set_AbortButton(Button value) in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Dialog.cs:line 148
at Rhino.UI.Internal.TabPanels.Controls.WindowLayoutsDialog.<>c__DisplayClass0_0.<Show>b__0(Object s, EventArgs e)
at Eto.PropertyStore.TriggerEvent[T](Object key, Object sender, T args) in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\PropertyStore.cs:line 233
at Eto.Forms.Control.OnShown(EventArgs e) in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Controls\Control.cs:line 466
at Eto.Forms.Control.Callback.OnShown(Control widget, EventArgs e) in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Forms\Controls\Control.cs:line 1674
at Eto.Wpf.Forms.WpfWindow`3.<AttachEvent>b__41_6() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfWindow.cs:line 256
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
When our plugin opens I’d like to get a list of all window layouts, and if our layout is not installed to install it.
I can’t see an automatic way. Might be worth including a version number in the name of the layout in this case as any imported layout does not overwrite.
