Hi all,
i tried to create a recursive function with python that choose a random point from a nearest points group.
It works but now i want analyze the result and depending on some conditions i want to recall the function.
How can a function can be called again till the conditions is met?
import scriptcontext
import ghpythonlib.components as gc
import random
import Rhino
visiblept = [startpt]
cullindexin.remove(startpt)
def path(closestpt,cullist):
# 1
# choose a random point from nearest points and do this process recursiv
# store these random points in a list called visiblept
i = gc.ListItem(closestpt,random.choice(closestpt),True)
visiblept.append(i)
L = cullist
L.remove(i)
P = gc.ClosestPoints(i,L,5)[0]
if len(visiblept) <= iterator:
return path(P,L)
path(closestptin,cullindexin)
# 2
# create a polyline from visiblept and check for self intersection
Curveguid = rs.AddPolyline(visiblept)
Curve = rs.coercecurve(Curveguid)
events = Rhino.Geometry.Intersect.Intersection.CurveSelf(Curve,0.001)
# 3
# if self intersection is True do 1 again till selfintersection is False
# if len(events) > 0:
# HOW CAN I CALL THE PATH FUNCTION AGAIN
Any help is welcome.
