C++ Selecting multiple curve, some of them are not valid
I would like to ask how to retrieve multiple curves, and append to C++ collection only valid ones.
Essentially my simple question is what Collection type I should use to add valid curves when I do not know the fixed length of collection?
Second question: to retrieve all selected objects I have to write:
go.GetObjects(0, -1); ?
For example here I retrieve curve objects from rhino and if they are valid I would like to add them to a collection.
CRhinoGetObject go;
go.SetCommandPrompt(L"Select Curves");
go.SetGeometryFilter(CRhinoGetObject::curve_object);
if (go.CommandResult() != CRhinoCommand::success)
	return go.CommandResult();
//What kind of collection I should declare here <---------
for (int i = 0; i < go.ObjectCount(); i++) {
	//Get first object + validate
	const ON_Curve* crv = go.Object(0).Curve();
	if (crv == 0) {
		return CRhinoCommand::failure;
	else {
		//Question---------> add to curve list;
Hi @Petras_Vestartas,
Something like this?
CRhinoGetObject go;
go.SetCommandPrompt(L"Select curves");
go.EnableSubObjectSelect(FALSE);
go.GetObjects(1, 0);
const int object_count = go.ObjectCount();
ON_SimpleArray<const ON_Curve*> curve_list(object_count);
for (int i = 0; i < object_count; i++)
  const ON_Curve* crv = go.Object(i).Curve();
  if (nullptr == crv)
  if (crv->IsValid())
    curve_list.Append(crv);
const int curve_count = curve_list.Count();
for (int i = 0; i < curve_count; i++)
  const ON_Curve* crv = curve_list[i];
  if (nullptr == crv)
    continue; // should never get here...
  // TODO...
– Dale
Dear Dale,
Thank you very much. I see in most examples using this ON_SimpleArray
What is normally used in C++ (in wider context without Rhino) when you do not know exactly the length of collection?
The Rhino SDK had three different dynamic, template array classes:
1.) ON_SimpleArray<> - For use with simple data types (e.g. bool, int, double, etc.), pointers, and classes that do not have explicit construction, destruction, and copy operators.
For example:
ON_SimpleArray<double> parameters;
ON_SimpleArray<const ON_Curve*> curves;
ON_SimpleArray<ON_3dPoint> points;
2.) ON_ClassArray<> - For use with classes that require non-trivial construction or destruction. Any class used with the ON_ClassArray<> template must have a robust operator=().
For example:
ON_ClassArray<ON_wString> strings;
ON_ClassArray<CRhinoObjRef> objects;
3.) ON_ObjectArrray<> - For use with class that are derived from ON_Object.
For example:
ON_ObjectArray<ON_NurbsCurve> nurbs_curves;
ON_ObjectArray<ON_Layer> layers;
– Dale
Take a look at the Standard Template Library (STL), that is included with every C++ compiler. It contains a list-like collection called vector<T>, but also more complex collections like set, map etc.
https://en.cppreference.com/w/cpp/container
These also define so-called iterator objects, so you can easily iterate their contents:
std::vector<int> numbers;
numbers.push_back(1);
numbers.push_back(2);
for(std::vector<int>::const_iterator it = numbers.begin(); it != numbers.end(); ++it)
  const int& number = *it;
//modern cpp also has range-for loop syntax:
for (auto& number : numbers)
