Numphy and nested lists ![]()
I found the following about nested lists but I think it has to be simpler. Also, what is Numphy under
do you might know ![]()
question10.gh (2.3 KB)
List<List<int>>
This looks weird
List<List<List<List<int>>>>
More weird
Should you than go for dictonary
Can it not be something like:
List<int> numbersA = new List<int>{{0,1,2},{0,1,2},{0,1,2}}
It does not work
I still try to find a numphy equivalent of python for C#.
It does look weird, but that’s the way it works in .NET. Alternate ways to approach this would be to use arrays int[][][] or create you own type which can both store collections of values or collections of itself.
Let’s see if I can come up with something while typing on this tablet.
public sealed class NestedList<T>
private readonly List<T> _items;
private readonly List<NestedList<T>> _lists;
public NestedList(params T[] items)
_items = new List<T>(items);
public NestedList(params NestedList<T> lists)
_lists = new List<NestedList<T>>(lists);
public bool ContainsItems { get { return _items != null; } }
public bool ContainsLists { get { return _lists != null; } }
public void Add(T item) { _items.Add(item); }
public void Add(NestedList<T> list) { _lists.Add(list); }
public int ItemCount {
get
if (_items == null) return 0;
return _items.Count;
public int ListCount {
get {
if (_lists == null) return 0;
return _lists.Count;
public T ItemAt(int index) { return _items[index]; }
public NestedList<T> ListAt(int index) { return _lists[index]; }
// and so on and so forth.
Found this.
Found this.
It seems what I am doing is trying to make a new class similar to the class DataTree. But I do not know if the class DataTree is the conventional way to work with date within C#. Also, can you make branch-depths like {0;0;0;0;0;0} ![]()
However, to continue learning all aspects of C#, what I am doing wrong it the code you sent me ![]()
Small array above in the code is unrelated to that of the code below.
question10a.gh (4.2 KB)
DataTree<T> is a Grasshopper class. It is not something you will find in C# elsewhere.
Furthermore DataTree<T> is a simplified version of the GH_Structure<T> class which is used internally in Grasshopper to store all data. The problem with GH_Structure<T> is that it demands T implements the IGH_Goo interface. This was an unwelcome constraint within the context of C# and VB script components.
You can certainly use it though, and the paths used to identify the various lists in the tree can be set up to mimic a nesting structure.
Thank you David. By the way, my previous post, do you see why I get that message of line 79 (image)?
In case this helps…
private void RunScript(object x, object y, ref object A)
List<List<int>> numbers = new List<List<int>>{new List<int>(){0,1,2},new List<int>(){0,1,2},new List<int>(){0,1,2}};
List<List<int>> numbers2 = ListMe(ListMe(0, 1, 2), ListMe(0, 1, 2), ListMe(0, 1, 2));
int[][] numbers3 = new int[][]{new []{0, 1, 2}, new []{0, 1, 2}, new []{0, 1, 2}};
// <Custom additional code>
public List<T> ListMe<T>(params T[] items)
var list = new List<T>();
list.AddRange(items);
return list;
Ah, that’s supposed to be
public NestedList(params NestedList<T>[] lists)
I forgot the array brackets for the argument, they are required when your function argument has the params qualifier.
C# has multidimensional array, which is different from nested array.
int[,] arr=new int[3,2]{{1,2,3},{1,2,3}};
Perhaps this is similar to numpy something.
