Not in visual studio but in c sharp editor in grasshopper, I would like to make error on purpose.
Let say
if(i = 0)
ComponentBecomeRed and display a message
How can I make this?
Let say
if(i = 0)
Assigned to Grasshopper category
Instead of red I would suggest:
try{ some stupid thing }
catch{ Print(“Stupid thing did stupid things”);}
That way you can “trace” N errors
Like this:
for Warning (yellow/orange)
this.Component.AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, “Warning message.”);
or for Error (red)
this.Component.AddRuntimeMessage(GH_RuntimeMessageLevel.Error, “Error message.”);
You might want to put
return;
after an error to stop the script.
In addition to @Michael_Pryor and @PeterFotiadis suggestions, any exception thrown inside the script will be caught and put into the RuntimeMessage list as an error. So
throw new Exception("You're not allowed to divide by zero.");
would both immediately stop the execution of your script and log an error.
this.Component gave me an error
I used this.AddRuntimeMessage() directly like this:
this.AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, "Warning message.");
If you’re using VS to compile your code, then your code is already inside a Component class. For C# scripts however that is not the case. In scripts you have to access the Component field to get that functionality.
that makes sense! thankyou so much.
in VS you won’t even need the “this.”
wow cool. thanks
Hi, quick question on this topic. If try and catch is added to a static method, is it still possible to add a runtime message? Apparently, Component is non-static and does not allow it. It could be useful to find a workaround. Thanks
