i used python in grasshopper to make components referring to > help > rhinoscriptsyntax
now i am trying learn and decode C# script in grasshopper … but i cant find a way to refer these C# syntax to understand them
Only Python uses the RhinoScriptSyntax, which was developed to ease transition from RhinoScript to Python.
In C# you’ll have to switch to standard RhinoCommon classes and methods.
can you please help me out how to use rhinocommon… itz bit confusing
for example
referring to this C# script
i cant find " CreateTri " in RhinoCommon
//Create an empty list of lines to hold our snowflake curves
List<Line> lines = new List<Line>();
//Call the CreateTri function and pass the radius and flip parameters
Polyline tri = **_CreateTri_**(radius, flip);
//Create an array of Lines by extracting the segements from the triangle
Line[] triangle = tri.GetSegments();
//Add these three lines to the lines List
lines.Add(triangle[0]);
lines.Add(triangle[1]);
lines.Add(triangle[2]);
//Create a temporary list of lines
List<Line> tempList = new List<Line>();
//Begin the while loop
int i = 0;
while(i < num){
//make sure the list is empty by calling the Clear() method
tempList.Clear();
tempList.AddRange(lines);
lines.Clear();
lines.AddRange(CreateKochSnowflake(tempList));
i++;
A = lines;
And what’s the CreateTri
function like?
i guess itz for making triangles
Not what for, what’s it like? I.e. how does it work? I don’t think it’s a McNeel function, unless someone has seriously changed naming conventions we tend to use.
CreateTri(radius, flip)
i have no idea sir
Polyline triangle = CreateTri();
List<Line> lines = new List<Line>(triangle.GetSegments());
for (int i = 0; i < num; i++)
List<Line> temporary = new List<Line>(lines);
lines.Clear();
lines.AddRange(CreateKochSnowflake(temporary));
A = lines;
This would be the C# way of doing it, but the CreateTri()
and CreateKochSnowflake()
methods are not available in Rhino. I don’t know where you go them from but I imagine they are provided by some sort of python import.
gh-csharp-adv02.cs (3.2 KB)
i got this from a tutorial
//http://www.designalyze.com/advanced-scripting-02-kochsnowflake
Dude it’s already in C#…
you mean CreateTri() is in C# by default ?
That webpage shows the source of the CreateTri and KochSnowflake methods in C#.
thanx man !!
