Hello
I develop a plugin in c# and I need a lot of input datas.
I save the datas in a Text File a this moment.
I want open a WindowsForm inside the plugin.
I create the window but hwo to open and closed.
// open the window…
Unroll.StartWindow…???
namespace Unroll
public partial class StartWindow : Form
public StartWindow()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
// Exit....????
Thanks I think without the samle I never get a window.
now it works.
namespace Unroll
this.OkBtn = new System.Windows.Forms.Button();
Unroll.StartWindow.ActiveForm.Close();
// TODO: start here modifying the behaviour of your command.
// open window
Result result = Result.Cancel;
if (mode == RunMode.Interactive)
Unroll.StartWindow form = new Unroll.StartWindow();
DialogResult dialogResult = form.ShowDialog(RhinoApp.MainWindow());
if (dialogResult == DialogResult.OK)
result = Result.Success;
else
string msg = string.Format("Scriptable version of {0} command not implemented.", EnglishName);
RhinoApp.WriteLine(msg);
// window is closed
