Our control cage structure actually allows for the deletion of points from the control cage structure. However, in rhino when I select grip(s) and tap delete, nothing happens (which is to be expected)
What is the easiest way to allow rhino to call a method in my CRhinoGripObject or CRhinoObjectGrips subclasses when the user tries to delete a grip?
Description:
Rhino calls DeleteGrips() when some of the object's grips
are deleted. If the object supports grip deletion, like
meshes, then DeleteGrips() should create a new object
by deleting the indicated grips.
Returns:
Pointer to the new object if successful. Rhino will
take care of adding this object to the document.
virtual
CRhinoObject* DeleteGrips(
ON_SimpleArray<int>& deleted_grips
