Hello.
I am trying to create a polyline (line with 2 or more segments) and copy it (translate it) to a different location.
This is what I have so far:
Point3d p1;
Point3d p2;
p1 =new Point3d(0,0,0);
p2 = new Point3d(0,0,10);
Line line1 = new Line(p1, p2);
p1 = p2;
p2[2] *= 2;
Line line2 = new Line(p1, p2);
List<Line> polyline1 = new List<Line>(5);
polyline1.Add(line1);
polyline1.Add(line2);
for (int i = 0; i < polyline1.Count; i++)
doc.Objects.AddLine(polyline1[i]);
So far so good. The lines are drawn in Rhino. Now I would like to take polyline1 and copy it to a different location, for example at x=20, x=30, etc.
Thank you very much
dale
(Dale Fugier)
April 27, 2017, 11:04pm
2
To more or copy something, you will need to create a translation transformation
var xform = Rhino.Geometry.Transform.Translation(direction);
where direction
is a vector that defines the magnitude and direction.
Tnd then apply this transformation to the geometry by calling it’s Transform
member;
var new_line = line.Transform(xform);
Does this help?
– Dale
Please accept my apologies for not replying earlier.
This was very helpful. Thank you very much!
fraguada
(Luis Fraguada)
May 10, 2017, 6:06pm
4
Just a small comment on your code. You’ve actually created two lines, not a polyline. If you want two, not joined lines, that is fine. If you want a polyline with two segments, you should take a look at the Polyline Class . If you just want to add it to the document, you can do that by calling doc.Objects.AddPolyline(YourPointList);
Yes Yes! Thank you for the comment! It is more than welcome
I was playing with this the other day, Can you explain how it works here?
Rhino.Collections.Point3dList points = new Rhino.Collections.Point3dList(11);
points.Add(-7.090,0,5.86);
points.Add(-6.00,0,5.86);
points.Add(-6.00,0,4.02);
points.Add(-3.84,0,4.02);
points.Add(-3.84,0,3.03);
points.Add(-4.234,0,3.03);
points.Add(-4.234,0,0);
points.Add(-4.835,0,0);
points.Add(-4.835,0,3.0034);
points.Add(-7.00,0,3.0034);
points.Add(-7.00,0,5.86);
Rhino.Geometry.Polyline nc = Rhino.Display.DisplayPipeline.DrawPolyline(points);
Rhino.Commands.Result rc = Rhino.Commands.Result.Failure;
if (nc != null && nc.IsValid)
if (doc.Objects.AddPolyline(nc) != Guid.Empty)
doc.Views.Redraw();
rc = Rhino.Commands.Result.Success;
return rc;
I was starting with this … https://developer.rhino3d.com/en/samples/rhinocommon/add-nurbs-curve/
Thanks,
«Randy
dale
(Dale Fugier)
May 30, 2017, 6:23pm
7
@rhinorudi
This code should make a bit more sense, as you really shouldn’t create a Polyline by calling .DisplayPipeline.DrawPolyline
points.Add(-7.090, 0, 5.86);
points.Add(-6.00, 0, 5.86);
points.Add(-6.00, 0, 4.02);
points.Add(-3.84, 0, 4.02);
points.Add(-3.84, 0, 3.03);
points.Add(-4.234, 0, 3.03);
points.Add(-4.234, 0, 0);
points.Add(-4.835, 0, 0);
points.Add(-4.835, 0, 3.0034);
points.Add(-7.00, 0, 3.0034);
points.Add(-7.00, 0, 5.86);
Rhino.Geometry.Polyline polyline = new Rhino.Geometry.Polyline(points);
if (polyline != null && polyline.IsValid)
if (doc.Objects.AddPolyline(polyline) != System.Guid.Empty)
doc.Views.Redraw();
return rc;
– Dale
Hi @dale thanks. That makes more sense. I am trying to learn by playing with the samples.
«Randy
dale
(Dale Fugier)
May 30, 2017, 6:40pm
9
Here are lots of good samples here:
– Dale
