C# component icon
@stevebaer Thanks for this, I had a similar issue using Rider. I was following @LongNguyen recorded workshop. This is what ended up working for me:
  1. Make sure the 24x24 icon is an ‘Embedded Resource’
  2. Use a stream, but with the EndsWith recommendation found on this Stack Overflow: https://stackoverflow.com/a/62808651/1026169
Here is the code that finally worked from the .cs file:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Linq;
using System.Reflection;
using System.Runtime.Versioning;
using Grasshopper;
using Grasshopper.Kernel;
using Rhino.Geometry;
namespace Plugin_1_Day_3
  public class Averages : GH_Component
    /// <summary>
    /// Each implementation of GH_Component must provide a public
    /// constructor without any arguments.
    /// Category represents the Tab in which the component will appear,
    /// Subcategory the panel. If you use non-existing tab or panel names,
    /// new tabs/panels will automatically be created.
    /// </summary>
    public Averages()
      : base("Averages", "Computes Averages",
        "Workshop Test Component - Averages",
        "Workshop", "Utilities")
    /// <summary>
    /// Registers all the input parameters for this component.
    /// </summary>
    protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
      pManager.AddNumberParameter("first num", "first", "the first num", GH_ParamAccess.item, 0.0);
      pManager.AddNumberParameter("second num", "second", "the second num", GH_ParamAccess.item, 0.0);
    /// <summary>
    /// Registers all the output parameters for this component.
    /// </summary>
    protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
      pManager.AddNumberParameter("Average", "Average", "average of inputs", GH_ParamAccess.item);
    /// <summary>
    /// This is the method that actually does the work.
    /// </summary>
    /// <param name="DA">The DA object can be used to retrieve data from input parameters and
    /// to store data in output parameters.</param>
    protected override void SolveInstance(IGH_DataAccess DA)
      var nums = new List<double>();
      double a = double.NaN;
      double b = double.NaN;
      nums.Add(a);
      nums.Add(b);
      DA.GetData(0, ref a);
      DA.GetData(1, ref b);
      double average = 0.5 * (a + b);
      DA.SetData(0, average);
    /// <summary>
    /// Provides an Icon for every component that will be visible in the User Interface.
    /// Icons need to be 24x24 pixels.
    /// You can add image files to your project resources and access them like this:
    /// return Resources.IconForThisComponent;
    /// </summary>
    //protected override System.Drawing.Bitmap Icon => null;
      get
        var assembly = System.Reflection.Assembly.GetExecutingAssembly();
          var resourceName = assembly.GetManifestResourceNames().Single(n => n.EndsWith("icon.png"));
          var stream = assembly.GetManifestResourceStream(resourceName);
          if (stream != null) return new Bitmap(stream);
        return null;
    /// <summary>
    /// Each component must have a unique Guid to identify it.
    /// It is vital this Guid doesn't change otherwise old ghx files
    /// that use the old ID will partially fail during loading.
    /// </summary>
    public override Guid ComponentGuid => new Guid("6CBE441F-4367-4146-9755-BF7296D4BFE1");
Here’s how it turned out:
Also, kinda unrelated, but making a big difference for me with this kinda stuff. This plugin makes learning to write C# plugins so much less tedious:
