I have a bug in the French version of rhino 8 (I say this because I haven’t seen any comments on the internet so far.)
When I want to use the “intermediate curve” function between 2 curves, I never get a good result, as was the case in previous versions of Rhino.
Impossible to move the starting points to organize the distribution.
I specify that the curves are simple. they are composed of the same number of segments.
I should also point out that I have a 3Dconnexion space navigator which, before modifying the device’s dashboard, did not work as on previous versions of Rhino. I don’t see why there would be an interaction, but since I can’t even move my starting points with the “intermediate curve” function, I tell myself that everything is possible.
Hi @TuckerTheDog
Use CrvSeam before to move and align the seam and direction of the two curves. I never really understood why it isn’t part of the command to be able to move the seam for closed curves
HTH, Jakob
