Bug: rs.CreatePlane() not working in Py3
Hi all,
Code below is simple. In py2 it works well, but in Py3 it gets error messages:
“if raise_on_bad_input: raise TypeError(”%s can not be converted to a Plane"%plane)
TypeError: 0,0,0 can not be converted to a Plane"
plane = rs.CreatePlane(rs.CreatePoint(0,0,0), rs.CreateVector(1,0,0), rs.CreateVector(0,1,0))
print(plane)
Version: Rhino 8 SR8
I see that… @Alain ?
As a workaround you can use
#! python 3
import Rhino
plane = Rhino.Geometry.Plane(rs.CreatePoint(0,0,0), rs.CreateVector(1,0,0), rs.CreateVector(0,1,0))
print(plane)
You can also use other methods to create points or vectors such as Rhino.Geometry.Point3d(0,0,0)
@Helvetosaur ,
thx for the workaround.
Logged here: RH-82892
Thanks!
