In Rhino 6 WIP, BlendSrf has the option to Edit blended surfaces that were made with history enabled. However, if you use the ChainEdges functionality for a surface blend once, it will always automatically return to the ChainEdges submenu when calling BlendSrf the next time. Because this happens, I am unable to use the Edit functionality anymore. The only way to fix this is by restarting Rhino (it then forgets the ChainEdges choice and again gives you the choice between ChainEdges and Edit).
Hi Luc - thanks, I see that.
Hi Sach - No. In fact it looks like I never logged a bug for it , at least I cannot find it. I added a new one just in case. Thanks…
https://mcneel.myjetbrains.com/youtrack/issue/RH-37891
Great Pascal.
Thanks
