I think that there is a problem with mapping inside blocks:
- make box, map it with box mapping
- make block using that box
- rotate block, e.g. by 30 deg
- edit block, confirm editing
Widget position will change.
Best regards.
Alex
Best regards.
Alex
Got that, thanks!
Bug report: http://mcneel.myjetbrains.com/youtrack/issue/RH-24656
(these are not, currently, visible to the public)
Hi Pascal,
After 20140609 problem exist but it differs a bit now:
Best regs.
Alex
Hi Alex- OK, thanks- that bug item is still on the pile, so as far as I can see nothing has changed there.
