I’m facing what appears to be a bug in Rhino 7 for Curve.OffsetOnSurface. I recently upgraded from Rhino 6 to Rhino 7 and observe new behavior for offsetting of curves on a surface.
I’ve attached a script and screenshot of the behavior. I’ve tried to make the simplest possible script to recreate the behavior, which I first noticed on far more complex geometry. However, even simple geometry is behaving in unexpected ways.
The example shows a basic arc which I’m offsetting in a planar surface. The offset should be 1 at parameter 0 on the curve, 0.5 at 0.5, and 1 at 1. The result is a curve that is offset by unusual amounts to either side of the starting curve.
Please review my script and make sure I’m doing things properly. What I would expect is a curve that is offset by 1 at the ends and 0.5 in the middle, on one side of the starting curve (not crossing it).
BugReport_Curve-OffsetOnSurface.gh (16.0 KB)
