It is a about layer filter:
Looking at the layer structure, having Matching Method selects as Ends With it still selects the axis layer.
Query Model Layer selects it correctly:
You may want to share the file or a simplified version…
Any tip how to handle this situation?
I want to remove sublayer from selection which I could do after Query Model, but Explode is damaging the whole scene.
Test file attached. The goal is to load boxes only without exploding the block.
BOXES test.3dm (167.4 KB)
I think you first need to sort based on object type. Explode is needed to see what is inside the block.
2026-11-20_get-boxes.gh (13.1 KB)
It all depends how you manage your objects…
True. You, actually, provided superb solution by separating blocks from other geometry. 10 pts for you.
