Hi Steve,
could you check the code for FitCurve? It somehow does fit the curve, but then unfortunately returns the old input curve.
Thanks,
Andi
Hi Steve,
Thanks,
Andi
Yeah, this does look like a bug…
(original from curve.py)
curve = rhutil.coercecurve(curve_id, -1, True)
if distance_tolerance is None or distance_tolerance<0:
distance_tolerance = scriptcontext.doc.ModelAbsoluteTolerance
if angle_tolerance is None or angle_tolerance<0:
angle_tolerance = scriptcontext.doc.ModelAngleToleranceRadians
nc = curve.Fit(degree, distance_tolerance, angle_tolerance)
if nc:
rhobj = rhutil.coercerhinoobject(curve_id)
rc = None
if rhobj:
rc = scriptcontext.doc.Objects.AddCurve(curve, rhobj.Attributes)
else:
rc = scriptcontext.doc.Objects.AddCurve(curve)
if rc==System.Guid.Empty: raise Exception("Unable to add curve to document")
scriptcontext.doc.Views.Redraw()
return rc
return scriptcontext.errorhandler()
I think it should be:
if nc:
rc = None
if rhobj:
#changed curve to nc
rc = scriptcontext.doc.Objects.AddCurve(nc, rhobj.Attributes)
else:
rc = scriptcontext.doc.Objects.AddCurve(nc)
return rc
Don’t guarantee I’m right though…
–Mitch
That looks correct Mitch. I’ll make sure this is fixed in SR8. Thanks!
