Hi there,
I am reporting a bug here although it might not be used very often.
It happens once the Equality Component interacts with Curve Closest Point Component.
I enclose a screenshot and a .gh file for a detailed explanation.
[BUG] Equality Component.gh (19.6 KB)
The following is what this script for.
Objective: Find out the interior curves
Steps:
1#Create the exterior curve
2#Find all the mid points of the curves
3#if the mid points on the curve, then it is curve inside the exterior curve.
BUG:
So to determine if the mid points are on the curve, I can either
a#use the Distance output from Curve Closest Point Component. If it is 0, then cull that curve. The BUG happens here.
b#use Point/Region relationship from Point In Curve. This works.
