I am using RhinoCommon to scale objects and I came across this strange behavior. I’ve extracted the important code into a command:
using Rhino;
using Rhino.Commands;
using Rhino.Geometry;
using Rhino.Input.Custom;
namespace LayupRH.Commands
public class MyScaleConstant : Command
public MyScaleConstant()
Instance = this;
public static MyScaleConstant Instance { get; private set; }
public override string EnglishName => "MyScaleConstant";
using GetObject gb = new();
Brep brep;
gb.SetCommandPrompt("Select a brep to scale");
gb.GeometryFilter = Rhino.DocObjects.ObjectType.Brep;
if (gb.Get() == Rhino.Input.GetResult.Cancel)
return Result.Cancel;
brep = gb.Object(0).Brep();
Transform transform = Transform.Scale(
new Plane(Point3d.Origin, Vector3d.ZAxis),
0.99,
0.99,
0.9
brep.Transform(transform);
brep.Repair(0.001);
doc.Objects.Add(brep);
return Result.Success;
When I call it on the big shape,
I get the small shape
which has doesn’t match on the inside edges.
Is this a bug with the transformation? If so, is there a way to detect this kind of behavior? For my purposes I need to use RhinoCommon to scale a variety of shapes.
File with the shapes:
brokenScaling.3dm (167.7 KB)
Process for replication: Use the custom command on the bigger shape and it creates the smaller shape.
Thank you,
- Russell
