Hello everybody.
I want to create a Brep with a hole from 2 concentric curves for example:
When I want to create a Brep whitout holes, I call the following function.
Surface mySurface= Surface.CreateExtrusion(curva, new Vector3d(0, 0, 10));
mySurface.ToBrep();
I have tried to create 2 breps with each curve and to use Brep.CreateBooleanIntersection() Brep.CreateBooleanDifference(),but not work.
Someone can help me?
Thank you.
Willem
(Willem Derks)
July 14, 2015, 12:24pm
2
Hi Miguel,
You can use
Breps = Rhino.Geometry.Brep.CreatePlanarBreps(ocurves)
and next extrude the Brep face(s) with BrepFace.CreateExtrusion(curve, cap)
HTH
-Willem
Thank you very much for your answer Willem. But I don’t kwow how I can use this functions. Can you put a example please?
I write the following code:
List<Curve> listCurves= new List<Curve>() { curveExt, curveInt};
Brep brepAux = Brep.CreatePlanarBreps(curvasPlancha)[0];
And the brepAux is correct, but planar. How I can extrude brepAux with BrepFace.CreateExtrusion(???,false);
Thank you again.
I get it!
BrepFace.CreateExtrusion(CurvPath,bool);
Where CurvePath in my case is
brepFace.CreateExtrusion(new LineCurve(new Point3d(0,0,0),new Point3d(0, 0, 30)), true);
i.e, the path that extrusion has to follow.
All code is:
List<Curve> curvasPlancha = new List<Curve>() { curvaInterior, curvaExterior };
Brep aux = Brep.CreatePlanarBreps(curvasPlancha)[0];
Brep aux2 = aux.Faces[0].CreateExtrusion(new LineCurve(new Point3d(0,0,0),new Point3d(0, 0, 30)), true );
Thanks.
