Brep.SolidOrientation confusion
Hi there,
this is kind of trivial problem, but I am not quite sure if i understand Brep.SolidOrientation correctly.
I would assume that this is a Brep.SolidOrientation.Outward as the normals seem to point out of the closed volume of the brep.
Rhino.Common tells me this is Brep.SolidOrientation.Inward though.
In the documentation I did not find anything more specific, so I thought that someone here might help me understand this.
Thanks,
T.
Hi @tobias.stoltmann,
Yes.
The screen capture doesn’t help much. Is there anything else to look at?
– Dale
Hi @dale ,
well, I just tried to reproduce some item, but the orientation for everything I was able to create is Outward now.
Basically I just tried to understand what defines the orientation and how to check it.
But I also can totally live with the fact that I will check the orientation and flip it if it’s inward.
