Hello, Team
private void RunScript(Brep B, Plane P, out object Curves, out object Points)
// Write your logic here
Curve Crv;
Point3d Pts;
Rhino.Geometry.Intersect.Intersection.BrepPlane(B, P, 0.001, out Crv, out Pts);
Curves = Crv;
Points = Pts;
This is how we solve Brep|Plane intersection in C# (using Rhinocommon)
It seems trickier to do the same in Python ( I can’t clarify how to assign ‘out Crv’ and ‘out Pts’ arguments in Python.
Can you, please, help me create the correct script in Python? Thanks
pls. see a pic attached
Hi, I don’t have access to Rhino right away but in general, Python accepts a,b=F(var1,var2) syntax, i.e., you can retrieve more than one return values from a function. In many cases, ‘out’ parameters can be retrieved that way.
Usually I just do something like this:
insec=Rhino.Geometry.Intersect.Intersection.BrepPlane(brep,split_plane,tol)
if insec and insec[0]:
if insec[1]:
#your list of curves (if any) will be insec[1]
#do something
if insec[2]:
#your list of points (if any) will be insec[2]
#do something
Thank You Helvetosaur,
I solved the problem according to mikity_kogekoge’s advice.
I will try ur script as well.
