Brep.CreateBooleanSplit() w/only one brep to split and multiple cutters
There are two overloads, one with one base object to split and one cutter, the other with multiple base objects and multiple cutters:
However I have one base object and multiple cutters. I first tried just passing one brep as the first argument, but it told me it expected an IEnumerable[brep]. So I tried just making a list from the one brep, certain it was going to fail, but it actually worked (more or less).
splits=Rhino.Geometry.Brep.CreateBooleanSplit([obj],cut_srfs,tol)
For an object that should have been split in three, I got four results, one of which was None.
I can of course filter that out after, but I was wondering what is the “right” way to do this?
I think the code you wrote is the correct approach (first input in a list).
What probably happens is that CreateBooleanSplit method splits the first input iteratively. So it takes the first cutter, split the first input into two/more pieces. Then checks if the second cutter intersects the any of the two/more pieces. If it does, it deletes that one (already split) piece and creates new pieces from it. And so on. All these deleted pieces are returned as ‘None’.
My thought is similar to Djordje’s but I think the brep is split with the first and then the resulting breps are split with the second, of which one gives a None result. Since there is no awareness of where the objects are located I assume this is just done brute force.
Are you splitting a closed polysurf? If so, does this method return a closed or open polysurf? If open, and if Cap open polysurf doesn’t work, how would you close it?
Edit:. I see you had a big discussion on topics surrounding this today as well…
The result of cutting a solid is a solid, and the result of cutting an open surface is an open surface. Why is your thinking so complicated
If you don’t want to close, just delete a face
Splitting a closed object. It should return a closed object as well, that is the purpose. If you are splitting a closed object with a curved surface then Cap will not work to close the object as the opening is not planar. Hence the use of BooleanSplit, which works similarly to the native Rhino command.
Otherwise, just like you would do with native Rhino commands, it’s necessary to code with just Brep.Split() which leaves the object open, then get the splitting surface, split that as well, figure out which part of the surface you want to keep and then join that to the rest. That’s just a lot more coding.
This comment is unrelated to the original request…
