I have some parts rotated say 45 degrees on X axis and I need to form bounding box on that plane.
I tried inserting normal plane extracted from a surface rotated 45 degrees and I connected it to bounding box plane but still bounding is not aligned to plane. Currently I am rotating negative 45 degrees of the parts and form bounding box and rotate bounding box again 45 degrees. How to avoid this step? Please Help
The solution below provides either three (oriented) BoundingBoxes or a single BoundingBox for the entire group. Remove the “Group” component if you want three BoundingBoxes:
