Hi All,
I am having an issue with Boolean Differences
beam = beam.CapPlanarHoles(0.01);
beam = Brep.CreateBooleanDifference(beam, end1Box, 0.001)[0];
DA.SetData(0, beam);
the beam is a solid, end1Box is a solid
I can return beam and end1Box individually from the code, however, when I run the CreateBooleanDifference it returns it as 1 big Brep.
If I take the 2 Breps individually and is the Solid difference node, it works as expected.
Have I misunderstood or missed something in the code?
import Rhino.Geometry as rg
create two spheres
sphere1 = rg.Sphere(rg.Point3d(0, 0, 0), 5)
sphere2 = rg.Sphere(rg.Point3d(2, 0, 0), 5)
create two breps from the spheres
brep1 = rg.Brep.CreateFromSphere(sphere1)
brep2 = rg.Brep.CreateFromSphere(sphere2)
perform boolean difference
result = rg.Brep.CreateBooleanDifference(brep1, [brep2], 0.001)
output the result
a = result[0]
(It’s an ai generated code try something like this may be it will work, you can use "get geometry"instead of using create from sphere
[ Something like this
create two geometry inputs
geo1 = x[0]
geo2 = x[1]
create a Brep representation of the first geometry input
brep1 = rg.Brep.TryConvertBrep(geo1)
create a Brep representation of the second geometry input
brep2 = rg.Brep.TryConvertBrep(geo2)
perform a Boolean difference operation
result = rg.Brep.CreateBooleanDifference(brep1, brep2, 0.001)
output the result
if result: # if the Boolean difference operation was successful
output = result[0] # output the resulting geometry
else:
output = None # if the Boolean difference operation failed, output None
Thanks for the reply. I completely forgot to mention that I am writing a custom node using C#. I don’t think it would make a difference, but thought I’d mention it
Found the solution. Beam had SolidOrientation as Inwards, and the box as outward. Once I flipped the beam, worked as expected
Check surface normals. Usually boolean difference ending up as a union can be an inverted set of normals.
