Blocks handling in Grasshopper
Can Grasshopper hadle blocks ?
I have imported geomety into Rhino from ArchiCAD but they appear as blocks, which I cannot select in Grashhoppper. Exlopding is not really a solution beacuse they fall apart into several geometry and joining them does not really work.
Not without a plug-in like, e.g. Elefront or Human.
I have human installed but theres is no block item among the reference menu.
not to be confused with Human UI
I know.
But I connot find the block element within.
Under Reference tab?
there is block explode but no block, which I could use as reference
Use Elefront. It has more options for block handling.
