-BlendSrf - AddShapes not working
Calling -BlendSrf and clicking add shapes (tried to macro going straight into adding a shape) doesn’t appear to work.
Hello - I believe this is a command line problem - what happens if you type the option name?
Still prompted with ‘Pick Shape to remove’ - Even clicking AddShape doesn’t work. Is there only a very specific condition when AddShape can be used?
EDIT - Sorry I should be more clear - I’m alluding to that it’s a problem with the suppressed dialog version (-BlendSrf, not the standard BlendSrf).
Yep, I got it now - thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-54894
Just tested as working in Rhino 5 too, with ‘a’ for input. So I guess it’s a regression?
