Hi @dale,
i am trying to get the objects which are transformed using an BeforeTransformObjects Event handler in Rhino 5 SR12. Below code toggles the event handler:
import Rhino
import scriptcontext
def MyTransformEvent(sender, e):
print e.Objects
def DoSomething():
key = "MyTransformEvent"
if scriptcontext.sticky.has_key(key):
print "Event DISABLED"
scriptcontext.doc.BeforeTransformObjects -= scriptcontext.sticky[key]
scriptcontext.sticky.Remove(key)
else:
print "EVENT ENABLED"
scriptcontext.sticky[key] = eval(key)
scriptcontext.doc.BeforeTransformObjects += eval(key)
if __name__=="__main__":
DoSomething()
While the event is enabled, in Rhino 5 SR 12 the MyTransformEvent function always returns None for the objects beeing transformed while in Rhino 6 WIP, i get this result, eg. when a single point is transformed:
Array[RhinoObject]((<Rhino.DocObjects.PointObject object at 0x000000000000002E [ModelGeometry: (unnamed) (0)]>))
Is there anything i can do to make it work in Rhino 5 and get the objects beeing transformed ?
c.
