Baking did not produce single Brep
FROM two BREPS, the goal is to produce a single BREP.
From a small construction with a sphere and a closely related extrusion, I’m trying to produce a unitary BREP (in order to use downstream to subtract from another BREP).
Each time I’ve tried baking what I hoped would be a single entity, I’ve ended up with two separate BREPs. A single one is surely possible, but the correct combination has eluded me.
I’m sure that someone with more experience will spot my error, possibly at a glance!
Experiment—02—.gh (14.8 KB)
In your screenshot, you can see that the output of the Brep Join component is a DataTree (dashed line). You need to flatten the input to the Brep Join component.
I have also eliminated a few unnecessary components.
Experiment—02—re.gh (14.1 KB)
-Kevin
KEVIN,
Thank you for your quick solution.
And the job of cleaning-up!
I expect it is likely to help others too.
