Alguien sabe porque pasa esto?
Cuando guardo y cierro un proyecto con imagenes jpg, al querer volver a abrirlo, las imagenes ya no se muestran, la unica forma de verlas es en “Render” y es un fastidio si quiero ir trabajando con blueprints poco a poco porque a la que cierro Rhino pasa esto, porfavor ayudaaa
Hi -
Please run the Rhino _SystemInfo
command and copy-paste the result here.
If you can also post a 3dm file that misbehaves on your system, that would help.
menos3.txt (2.2 KB)
Ese es el Systeminfo, el archivo 3dm no me dejo subirlo no se porque
Blueprints Tesla Setup.3dm (10.5 MB)
Ya me dejo
Hi -
Thanks,
The pictures appear to be correctly embedded in the file, which points to a system-specific issue.
Primary display and OpenGL: AMD Radeon™ RX Vega 11 Graphics (AMD) Memory: 2GB, Driver date: 8-26-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context 21.30.14 30.0.13014.8
The recommendation for Rhino 7 is to have 4GB of VRAM for each screen that is used. Your Radeon card only has two. You could try to update the drivers to their latest version to see if that helps.
