The GetPlugInObject method on the Rhino application object returns a COM object from a plug-in. The first parameter to the method is the UUID of the plug-in that you want the object from. The second parameter is the UUID of the object or type of object you want returned. In the example you reference, the plug-in only has a single COM object. Thus, the second parameter is ignored.
There isn’t much you can do with either the Rhino application or interface objects.
If this were implemented in .NET, this is what the class declaration might look like:
class RhinoApplication
// Shows or hides Rhino
public int Visible { get; set; }
// Gets the RhinoScript COM object (from the RhinoScript plug-in).
public dynamic GetScriptObject();
// Get a COM object from some plug-in.
public dynamic GetPlugInObject(string plugin_uuid, string interface_uuid);
// Runs a script or command macro (i.e. RhinoApp.RunScript).
public int RunScript(string script, int mode);
