Hello.
I have been learning Rhino for Windows in a digital fabrication class and recently installed Rhino 5 on my MacBook Pro to try out the Mac version.
I was hoping to use python to generate several interpolated curves from many data points.
I have a decent amount of python experience for exactly this situation - not as a real developer, but I use it all the time for solving problems like this.
However, after following the instructions to set up Atom with Rhino, I can’t run even a simple example script.
The Atom end appears to work fine (Rhino syntax autocompletion is working, RhinoPython appears in the packages menu), and I’m making sure that the Atom listener is running in Rhino. But every time I chose “Save and run in Rhino” from the Atom menu or use the ctrl+opt+R shortcut, I get an error in Rhino:
Exception occurred
Message: ‘module’ object has no attribute ‘AddLine’ (or AddCircle or whatever)
When I look at the info for both Rhino 5.3.2 and Rhino WIP, it tells me IronPython is not installed, but I thought this was supposed to be included with Rhino automatically?
Here is more info:
Software information
Software versions
Rhinoceros version: 5.3.2 (5D197)
IronPython version: not installed
Evaluation expiration: June 27, 2017
Language: en-US (MacOS default)
macOS version: Version 10.12.3 (Build 16D32)
Plug-ins
None
Third party kernel extensions
com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
Hardware information
Computer hardware
Hardware model: MacBookPro12,1
Processor: Intel Core i7-5557U CPU @ 3.10GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel Iris Graphics 6100 1536 MB
Memory: 1536 MB
Screen size: 1440 x 900
Displays: Color LCD (256dpi 2x)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.22.29
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
they might not see this post until tomorrow.
