doc = Rhino.RhinoDoc.ActiveDoc
render_mat= Rhino.Render.RenderMaterial.CreateBasicMaterial(Rhino.DocObjects.Material())
render_mat.Name="Wood"
existing_mat = [mat.Name for mat in doc.RenderMaterials]
if render_mat.Name not in existing_mat:
doc.RenderMaterials.Add(render_mat)
def create_layer(df):
existing_layer = [layer.Name for layer in doc.Layers if layer.IsDeleted == False]
for i in df:
if i[1]['LAYER_NAME'] not in existing_layer:
newlayer=Rhino.DocObjects.Layer()
newlayer.Name=i[1]['LAYER_NAME']
newlayer.Id=System.Guid.NewGuid()
newlayer.RenderMaterial=render_mat
print(newlayer.RenderMaterial)
try:
newlayer.Color= i[1]['RHINO_PEN']
except:
newlayer.Color= rs.CreateColor(255, 0, 0)
doc.Layers.Add(newlayer)
Please review the following and let me know if you have any questions.
import Rhino
import System
import scriptcontext as sc
def test_layer_with_material():
The properties of a Rhino material (Rhino.DocObjects.Material) define
what is required to draw an object using OpenGL. Most rendering plug-ins
require a much richer definition than this. And, not all rendering
plug-ins support the same material properties. This is where Render
materials (Rhino.Render.RenderMaterial) come in. A Render material
is an abstract material - one that is defined by the owning
rendering plug-in. But a basic Render material does share some
properties with a Rhino material.
This example demonstrates how to create a basic Render material.
This material will appear in Rhino's Materials panel. It it called a
basic material because it does not target any particular rendering plug-in.
# 1. Create a Rhino material
rhino_material = Rhino.DocObjects.Material()
rhino_material.Name = "Burly"
rhino_material.DiffuseColor = System.Drawing.Color.BurlyWood
# 2. Create a basic Render material from the Rhino material
render_material = Rhino.Render.RenderMaterial.CreateBasicMaterial(rhino_material, sc.doc)
# 3. Add the basic Render material to the document
sc.doc.RenderMaterials.Add(render_material)
At this point, you will see a Render material appear in Rhino's
Materials panel. Note, RhinoDoc.Materials.Count will equal 0. This is
because we have not added a Rhino material. We've only added a
Render material. When you assign a Render material to an object
or layer, a compatible Rhino material will be added to RhinoDoc.Materials,
and this material will be referenced by the Render material.
# 4. Now create a layer with the Render material assigned to it
layer_index = sc.doc.Layers.Add("Tobia", System.Drawing.Color.BurlyWood)
if layer_index > 0:
sc.doc.Layers[layer_index].RenderMaterial = render_material
if __name__ == "__main__":
From what I can see, my code didn’t work because I was treating the property Layer.RenderMaterial as Layer.Name or Layer.Color, so I was trying to apply it before pushing the layer in the document, am I right?
