Hi guys,
Is it possible to assign user data to a grasshopper component (GH_DocumentObject) ?Just like there is UserDictionary property for a RhinoObject , is there any equivalent for a GH_DocumentObject? Is there anyway we could assign something like a Key-Value pair to it?
Hi @Darryl_Menezes what exactly are you looking to do?
Hi @elevelle ,
I want to mark certain components with certain values. For example if I have 5 Number Sliders in a grasshopper file, I want to assign some user text to 2 of them (instead of assigning them names). So when I loop through the GH_Document.Objects, and find these 2 sliders and ignore the other 3.
GH_DocumentIO io = new GH_DocumentIO();
io.Open(FilePath);
GH_Document document = io.Document;
foreach (var obj in document.Objects)
if (obj is GH_NumberSlider slider)
//If this slider has the special key-value pair, then this is different from all other sliders in the file
Alternative would be to create a custom slider by inheriting the GH_NumberSlider, but I’m trying to avoid this.
Things I can think of:
- Serializing a dictionary to JSON (or alternative) and storing it in the Description property of the number slider.
- In a plugin, creating a static Dictionary<Guid,Dictionary<string,string>>, and storing the dictionaries for each slider by the object Guid.
In each case adding and removing key value pairs will most likely be awkward, or require a little coding to create a mini UI
A bit late, but for anyone wondering whats the best way for this, you can use a ConditionalWeakTable<object, Dictionary<string, string>> (replace objectwhere once the object is disposed, the key-value pair is automatically removed. You can kind of think of it as adding dynamically generated fields to objects
