Can anyone help me writing a simple scipt that assigns materials to layers with the same name?
To be clear, the material already exists.
Any help greatly appreciated
Hi @benjamin,
So you have a file with a number of named materials. Do you already have the layers created? Any additional details you can provide might be helpful.
Have you started a script? Can you post your code that isn’t working correctly?
You might also consider posting a sample 3dm file.
– Dale
Hi @benjamin, below is a simple one based on your description:
import Rhino
import scriptcontext
def AssignRenderMaterialToLayers():
layer_names = ["cupboard"]
material_name = "Cherry"
data = scriptcontext.doc.RenderMaterials.GetEnumerator()
mats = filter(lambda rm: rm.Name == material_name, data)
if not mats:
print "Material '{}' not found".format(material_name)
return
for layer in scriptcontext.doc.Layers:
if layer.Name in layer_names:
layer.RenderMaterial = mats[0]
The script assigns one existing material named “Cherry” to all layers named “cupboard”. You can add multiple layer names to the list at the top, eg.
layer_names = ["cupboard", "cabinet", "wardrobe"]
_
c.
Thanks clement!
Is there any way of assigning according to an existing list of materials?
To put it another way: the script lists all materials, then checks if there is an identically named layer, and assigns the material to the layer accordingly (if the material doesn’t have a corresponding layer then it skips it)
B
Hi @benjamin, try below:
import Rhino
render_materials = list(scriptcontext.doc.RenderMaterials)
if not render_materials: print "0 Materials found !"; return
data = dict()
for rm in render_materials: data[rm.Name] = rm
if layer.Name in data:
layer.RenderMaterial = data[layer.Name]
_
c.
Excellent - thank you! A nice little time saver ![]()
